  • 07:30
    6,3°C
    (0/8) Onbewolkt
    Windrichting: ZZW
    Windkracht: 5 = Vrij krachtige wind
  • 22:59
    8,7°C
Weerspecialist Bakker & Co Het magazine voor weerliefhebbers Weerhuisje Zenit
24-04-2013 March 2013 the globe's 10th warmest March
March 2013 was the globe's 10th warmest March since records began in 1880, according to NOAA's National Climatic Data Center (NCDC). NASA rated it the 9th warmest March on record. The year-to-date period of January - March has been the 8th warmest such period on record. March 2013 global land temperatures were the 11th warmest on record, and global ocean temperatures were the 9th warmest on record. March 2013 was the 337th consecutive month with global temperatures warmer than the 20th century average
Global satellite-measured temperatures in March 2013 for the lowest 8 km of the atmosphere were 12th or 8th warmest in the 35-year record, according to Remote Sensing Systems and the University of Alabama Huntsville (UAH), respectively. The Northern Hemisphere snow cover extent during March 2013 was the 16th largest in the 47-year period of record. Wunderground's weather historian, Christopher C. Burt, has a comprehensive post on the notable weather events of March 2013 in his March 2013 Global Weather Extremes Summary. He notes that one nation set an all-time heat record: on March 6th, Navrongo, Ghana reached 43.0°C (109.4°F), the warmest temperature reliably ever measured in the country (for any month.)
Figure 2. Departure of temperature from average for March 2013, the 10th warmest March for the globe since record keeping began in 1880. The Arctic Oscillation (AO), a large-scale climate pattern that can influence temperatures in the Northern Hemisphere, set a record low for March. This negative phase was associated with frigid Arctic air spilling southward into the Northern Hemisphere middle latitudes, leading to unusually cold conditions in the Eastern U.S., most of Europe, and northern Siberia.This phase of the AO also contributed to much warmer than average and even record warm temperatures in northeastern Canada and southeastern Greenland. A large swath of China and several regions in central and northern Africa in the 0°–20°N latitude belt were also record warm. Image credit: National Climatic Data Center (NCDC) .
Bron: Wunderground.
Wereld_Nieuws_2013
  • 17/2 08:59 Frank:
    Op Ambon, na een droge en vrij zonnige week met dagelijks maxima rond 34 gr.C, dauwpunten rond 23 gr. en minima van circa 24 gr., wordt het eiland thans getracteerd op een (gratis!) stortbui-douche. Tussen 09.00 uur en 15.00 uur plaatselijke tijd viel er vandaag op de luchthaven een welkome 44 liter per vierkante meter. Dat was hard nodig, zeker als je bedenkt dat de 12 uur-zon daar bijna in het zenit staat.
  • 17/2 08:24 Gert:
    zonnige start in de polaire lucht
  • 17/2 07:29 Hans:
    Ierse winter, ja klopt...Vanmorgen hier een vrij koude, matige ZW wind en vrij weinig bewolking bij 6.4 graden. We zitten weer in iets frissere lucht. (Enschede-W).
  • 17/2 01:25 Jurgen:
    Ik hoopte dat na het koufront de wind zou gaan afnemen, maar nu buldert het weer om het huis heen en houdt me uit de slaap. We beleven een Ierse winter...
  • 16/2 23:21 Hans:
    Lente-achtig qua temperatuur (Maxtemp 17.1 in Enschede-W), verder veeeel wind en de passage van een koufront rond 19.00. Neerslag over het etmaal 9.9 mm. Interessante weerdag!
  • 16/2 22:55 Ted:
    Correctie: 18,1 was niet in Arcen, maar in Ell. Arcen had 18,3 graden als landelijk hoogste waarde.
  • 16/2 19:55 Pieter:
    Arcen bereikte 18,1 C,maar in minder dan een uur daalde de temp. van 18,1 C naar 8,9 C
  • 16/2 19:48 Klaas:
    Friesland de hele dag in de koelere lucht, geen extreme wind, maar des te meer regen: Workum 31,5 mm en Siegerswoude (Ad Vermaas) ruim 37 mm. Dat komt in de buurt van het Friese februarirecord (39,2 mm te Joure op 9-2-1966, ijzel!!).
  • 16/2 19:09 Pieter:
    Tijdens en na koufrontpassage intensieve regenval (dagtotaal 20 mm), afnemende wind en dalende temperatuur van 14 naar 8 C
  • 16/2 18:24 Gert:
    Maar een keer eerder voorgekomen dat ik zo vroeg in het seizoen de 16C binnenhaalde sinds begin van de metingen in 1988. En wel op 14 feb 1998 ook 16C
  • 16/2 18:18 Erik:
    Afgaand op de grafieken van De Veenkampen waren de windstoten de afgelopen twee uren heftiger dan vorige week tijdens Ciara: toen kwam de max. snelheid op 10m hoogte niet boven de 25m/s, nu waren er twee windstoten boven de 25m/s, de sterkste iets van 28m/s.
  • 16/2 18:11 Erik:
    Excuses voor dubbele post. Snap nog steeds niet precies hoe het gebeurt, maar heeft te maken met page reload. Intussen vlagerige regen hier... Heftigste wind lijkt voorbij: die zat kennelijk voor de buienlijn uit.
  • 16/2 18:07 Marcel:
    Met zware windstoten liep de temperatuur in nunspeet op tot 16 g. Het viel lange tijd mee met de regen.... tot de rode streep arriveerde. Het werd heel donker en kort daarna gutste de regen door de straten. Dat was rond 17.45 uur. Temperatuur klapte omlaag naar 9,6 gr.
  • 16/2 18:05 Erik:
    Op station De Veenkampen bij Wageningen nu 17,1░C! Ik wacht nog steeds op het overtrekken van de buienlijn in Bennekom. Lucht wordt nu heel donker naar het zuidwesten toe...
  • 16/2 18:01 Erik:
  • 16/2 17:50 John:
    Hier in Oss net voor het koufront een onwerkelijke 18 graden!
  • 16/2 17:44 Gert:
    Buienlijn gepasseerd . Kort maar heftig 6mm
  • 16/2 17:42 Johan:
    Ook in de Bilt 16.7 c als max
  • 16/2 17:19 John:
    Kijk eens aan, intussen in Brabant gewoon gelijke windstoten als vorige week zondag. Net als Ko is het totaalplaatje aan wind heftiger dan vorige week.
  • 16/2 17:17 Gert:
    16c binnen koufront kan elk moment door komen
  • 16/2 17:13 Erik:
    De wind trekt hier in Bennekom op nadering van het koufront flink aan. Nog steeds extreem zacht: 16,7░C!
  • 16/2 17:12 Ko:
    Genieten van de stormachtige en beukende windvlagen. Op hoogte voelen we het zelfs ook, in tegenstelling tot vorige week. Het is dus nog iets heftiger.
  • 16/2 17:09 Dirk:
    Groot deel va het land 16/17 graden, in Sumar (Frl) ... 9 graden en regen.
  • 16/2 17:08 Gert:
    Buienlijn activeert
  • 16/2 16:54 Frank:
    Het koufront passeert nu Delft met een kortstondige striemende dichte regenvlaag (slecht zicht!) als in een tropische storm..
  • 16/2 16:19 Pieter:
    Het grootste windveld zit nu in het zuidwesten, Zeeland 6 tot 8 Bft In het noorden slechts 4 tot 5 Bft aanhoudeend regenachtig
  • 16/2 16:09 John:
    Op 4 februari 2004 was het met 17,6 graden nog warmer en eerder in de maand dan vandaag.
  • 16/2 15:57 Gert:
    Ik bedoel in de
  • 16/2 15:57 Gert:
    15c on de pocket
  • 16/2 15:29 Herman:
    Vandaag is extreem van 2007 verbroken door 16,6░ .
  • 16/2 15:17 John:
    Wild weer ook in Rijen. Niet veel minder dan vorige week zondag. Het is droog, boterzacht, knipoogje van de zon. Wind in vlagen toegenomen afgelopen uur, samenhangend met meer gradiŰnt door golfje op het koufront.
  • 16/2 15:15 Jurgen:
    Windveld verplaatst zich naar het zuiden. Nu in het zuidwesten de hoogste windkracht. Enorme stoten hier in Dordrecht. Echt ongezellig weer!
  • 16/2 14:37 Pieter:
    Zacht weer met veel wind en (mot) regen , 8 mm
  • 16/2 14:32 Klaas:
    In Workum zware regen rond 13 uur; de wind is afgenomen tot kracht 5 en het kwik gedaald neer 10 graden. Neerslag staat nu op 14 mm. Lekker binnen blijven.
  • 16/2 14:29 Hans:
    Enschede-W nu 15.5 graden met natuurlijk veel wind. Echter het lijkt wat mee te vallen, ook aan de kust. HÝer nog maar weinig regen, droog weer. De oude wijsheid "Veel wind, weinig regen" lijkt weer eens op te gaan.
  • 16/2 13:49 Gert:
    in Maarn nu 15,4 graden
  • 16/2 13:44 Gert:
    14.6 eens kijken of ik de 15c kan halen
  • 16/2 13:34 Ko:
    Het is hier helaas droog. Lekker fris buitenweer met wind. Heb zelfs meerdere joggers in korte broek gezien, zelfs dat kan gewoon met deze lente temp.
  • 16/2 12:40 Ted:
    Uitmuntend binnenzit weer. Bah! 12,6 graden met regen.
  • 16/2 09:38 Hans:
    Erg zacht (12.6) in het enschedese bij dikke 5 Bft met natuurlijk weer die uitschieters. In het zuiden al plaatselijk bijna 14 graden. En het gaat nog zachter worden...
  • 16/2 09:36 Hans:
    Met de regen is het nog mee gevallen (1.5 mm) tot nu toe. Zie je vaak bij zeer winderige, stormachtige omstandigheden. Regengebieden zijn verbrokkeld....
  • 16/2 08:08 Jurgen:
    Onwezelijk zacht de afgelopen nacht. Het kwik schommelde rond de 12 graden. Oftewel een zomernacht....Alleen de bulderende zuidwest passaat en lange nachten zijn anti-zomers.
  • 16/2 07:32 Gert:
    Op de maximale windstoten kaart van Weerplaza is te zien dat er in het Waddengebied al een zeer zware windstoot van 120 km /uur is gemeten. Al met al weer een onstuimige zondag hoewel het minder lijkt dan vorige week zondag. Anderzijds kwamen landinwaarts toen ook niet zeer zware windstoten voor.
  • 16/2 07:05 Gert:
    Boterzacht buiten met een stevige zuidwester. Neerslag 0.8mm
  • 16/2 05:29 John:
    Hier in Oss al uren lang regen en veel wind. Temperatuur momenteel 12,7, vannacht is het echter al 13,6 geweest.
  • 15/2 21:42 Hans:
    Het is al weer behoorlijk onstuimig buiten de deur en vandaag had ik 12.8 als maxtemp. Voorbode van het zeer zachte en stormachtige weer voor de zondag!
  • 15/2 21:06 Gert:
    Het zuiden van IJsland zit onder de 940. Druk in de kern 922 hPa
  • 15/2 18:38 Gert:
    De somberheid geeft in ieder geval het gevoel dat we in het winterhalfjaar zitten
  • 15/2 17:14 Jurgen:
    Even tegen het middaguur een paar opklaringen en boterzacht bij 12 graden. Maar voor de rest wederom een sombere dag. Deze winter valt niet alleen op door eindeloze zuidwesters, maar ˇˇk door gebrek aan zon. Jan+Febr zijn in jaren niet zˇ somber geweest...
  • 15/2 15:47 Ronald:
    Hier in Spijkenisse overwegend bewolkt vandaag, alleen begin de middag wat zonnige perioden. Flink aantrekkende wind nu, met Tact 11.6 C, en dan moet de lucht uit Madeira nog arriveren...
Ma 17 februari 2020
Er zijn 5 gasten en 1 lid aanwezig: Wilfred
